 Poignies CHROMES pour BRAVO
DreamAngel
DreamAngel
J'habite : 91
Poignies CHROMES pour BRAVO Empty
MessageSujet: Poignies CHROMES pour BRAVO   Poignies CHROMES pour BRAVO Icon_minitimeMer 7 Déc 2005 - 23:02
JE me demandais s'il serais pas possible d'adapter les poignies Chromes qu'on trouve sur les Alfa 147 et 156 sur nos Bravos.
J'ai deja observe ca de plus pres et franchement ca a l'air identique.
Surtout celles d'alfa 147
bravoboy
bravoboy
J'habite : Houilles 78; PARIS
Voiture : Bravo HGT+bmc+decata+intermediare supersprint+silencieux prowler
MessageSujet: Re: Poignies CHROMES pour BRAVO   Poignies CHROMES pour BRAVO Icon_minitimeMer 7 Déc 2005 - 23:14
La reponse est oui c adaptable, j ai vu un tuto la dessus :
Alfa 147 Handles Thanks to Ben Brown
Removal of Fiat Handle
Remove door card. Won't go into details here- Just undo everything, using allen keys and a philips screwdriver.
Use a torx tool (size 30) to undo the bolt on the side of the door, loosening one end of the handle.
Use a 10mm socket to undo the other end of the handle (inside the door cavity)
Push the handle forwards (ie towards the front of the car), then pull upwards firmly and eventually the handle should come loose.
There are 2 rods- one that pulls the door opener, one that locks/unlocks the door. Pull off the 2 rods from the handle. You'll need the little white bits on the ends too.
Leave the rod that pulls the door opener attached to the car.
Make a note of exactly where the kinks are in the locking-rod before removing this from both the door and the handle, so you can put it back in the right way up. You don't want to put this one back on upside-down or backwards, or you'll find it'll lock but not unlock!
With a little wiggling the old handle is now free.
Swithing locks
Pull the spring clip out that holds the lock barrel into the fiat handle. Then put your key in and use it to pull the lock barrel out of the handle. (Don't just try and prise it out cos you'll pull the metal top off the lock mechanism and have to spend ages reassembling that little flap- not that I did this of course!)
The lock barrel fits into the Alfa handle no problems. There's another spring clip holding this in.
There's a big chunky bit on the alfa handle's mechanism that isn't there on the fiat's:
Poignies CHROMES pour BRAVO Alfa1
Take a hacksaw to it to make it slimmer like this:
Poignies CHROMES pour BRAVO Alfa2
I also cut off the section shaded here, as it was knocking against the window runner inside the door, and not closing fully when you released the handle
Be really careful with the plastic lever on the back of the lock. If it breaks you'll have a working handle, but no working lock on that side of your car.
Refitting
Refitting the handle is really just a reverse of the dismantling. Reattaching the rods is easier if the little white bits are in the holes 1st, not on the rods.
Offer the handle up to the door and attach the opener rod(still attached inside the door) to the handle, then with the locking rod (unattached from the car), reach it inside the door and attach it to the handle 1st, feed the handle's bulky bits inside the door, then, looking through the gap in the door, (possibly getting someone to hold a light inside so you can see what you're doing), attach the door end of the locking rod. This seems complicated, but the locking rod is the most fiddly part of the whole job, and this way I found the quickest.
Removing the window runner may help too, to give you more room to work (only 2 10mm bolts). To get the handles back in, you can hook the top edge in place, and tap the handle upwards gently from below with a screwdriver resting on the lower lip, just enough to get the lip to slip into the door fully.
Any questions I could help with, email me ben_brown123@yahoo.com
[/url]
DreamAngel
DreamAngel
J'habite : 91
MessageSujet: Re: Poignies CHROMES pour BRAVO   Poignies CHROMES pour BRAVO Icon_minitimeJeu 8 Déc 2005 - 2:17
ouais j'ai pas tout compris....
En plus faut pas se rater vu que la poignie vaut 89€
Et faut voir si on peut recuperer la serure de la bravo....
Car apparament la il adapte la partie serrure mais c'est demontable sur bravo et la poignie reste nue (juste la coque)
je vais voir si je retrouve les anciennes poignies que j'ai demonte pour prendre des photos...
MessageSujet: Re: Poignies CHROMES pour BRAVO   Poignies CHROMES pour BRAVO Icon_minitimeJeu 8 Déc 2005 - 10:43
Tu peux récupérer ta serure sans probleme !
Parcontre, je croix qu'il faut couper une partie de la pate peinte en rouge sur la photo.
bravoboy
bravoboy
MessageSujet: Re: Poignies CHROMES pour BRAVO   Poignies CHROMES pour BRAVO Icon_minitimeJeu 8 Déc 2005 - 10:54
Oui tout a fait, il faut couper toutes les parties rouges des photos le reste du montage c est identique a une poignée de Bravo.
Yop
Yop
J'habite : Albi
Voiture : Bravo 1.6 16v
MessageSujet: Re: Poignies CHROMES pour BRAVO   Poignies CHROMES pour BRAVO Icon_minitimeJeu 8 Déc 2005 - 16:01
Il y a un tuto a ce sujet, va voir dans la section "tout sur la bravo" et le post regroupant tous les tutos, tu devrais trouver réponse a tes questions Wink
DreamAngel
DreamAngel
J'habite : 91
MessageSujet: Re: Poignies CHROMES pour BRAVO   Poignies CHROMES pour BRAVO Icon_minitimeMar 13 Déc 2005 - 0:09
Merci Yop j'aimerais bien me lancer la dedant mais une poignie comme celle ci vaut 89€ Sad
